Baofeng How can we connect/listen to a frequency with only 5 numbers?
Jinzo
I recently bought my first scanner, the Baofeng UV-5R. Been trying to find my local PD, and finally found some of what they use. However, their frequency is only 5 numbers, whereas on my screen I still need one more number.
Am I thinking about this wrong, are 6 numbers not needed? If 6 numbers are needed, how can I listen to this frequency?
gh6406
Dalton,Ga
The UV-5R is by no means a "scanner". That said, if the frequency you need to monitor is 155.34, then it would be 155.340. If there are only two numbers to the left of the decimal point, 45.875 then that is VHF Lo band and the baofeng will not pick that up.
Jinzo
The webpage I'm looking at, the frequency doesn't even have a decimal.
Example: 00-000
I assume the - is a replacement for the decimal?
Additionally, I've noticed that if a frequency ends in 0, upon pressing 0, it cancels my entire entry. I'm not sure why or how to bypass that.
ko6jw_2
Santa Ynez, CA
Did you use the RR database? Are you using Chirp to program the radio. Baofengs are not scanners. They scan too slowly. They don't cover all bands and they do not receive any digital mode like P25. They can't receive aircraft frequencies. Plus they lack banks, channel lockouts and other features of true scanners. Sorry you may be disappointed.
Some channels could be programmed with 4 digits. A local PD frequency here is 460.1MHz. On the other hand you might need 7 digits like 408.9875MHz. Rarely you might only need 3 digits for low band, but the Baofeng doesn't cover that band anyway.
nd5y
Wichita Falls, TX
What do you mean by "5 numbers"?
How many digits before and after the decimal point?
Trailing zeros after the decimal point are irrelevant but you might need to enter extra zeros for the radio to accept the frequency.
In order to enter frequencies from the keypad:
1. The frequency must be in the range the radio can receive (136-174 MHz or 400-512 MHz)
2. The radio must be in Frequency Mode (VFO Mode).
3. The radio must be set to the proper channel step size (MENU 1 STEP) to match the frequency you are trying to enter.
See: Baofeng UV-5R - The RadioReference Wiki
Jinzo
Obviously, I bought the wrong thing. All I'm interested in are scanners. Is the P25 recommended, or is there another one? or can y'all recommend a good one.
looks like a talkgroup number...
It is, webpage says frequency/talk group. I assume that's not usable.
fxdscon
¯\_(ツ)_/¯
It would be best if you could post a link directly to that webpage you are looking at so we can see exactly what you're seeing.
RACOM Network, EDACS Networked Standard is used by Police, Fire and Public Works in Moline Illinois. Your UV-5R radio will not pick that up, The 5 digit number in Quad Cities is the Talkgroup on the EDACS system.
CT
P25 is not a model.
Here is a listing of real scanners.
For a handheld I'd recommend a 325P2. For a base unit, a 996P2.
Both a real scanners.
If your area suffers from Simulcast, then you'll need an SDS model.
Good luck!
Jinzo
P25 is not a model.
Good luck!
Thanks, any slightly cheaper handheld ones? I'd be willing to spend 100-200, but $400 is a bit up there.
Would this one be good? https://www.amazon.com/Uniden-BC125...K368CE9707R&psc=1&refRID=VEMRQV0ASK368CE9707R
fxdscon
¯\_(ツ)_/¯
Here's some expanded reading and explanations on some of the terms mentioned:
CT
No digital and no trunking. From the Wiki:
" This is a fantastic scanner for its class, similar in design and function to the BC72XLT, BC92XLT and BC95XLT series of scanners, with a vastly improved set of features and narrow-band support. This is your best buy for a non-digital, non-trunking scanner; Made in 2012. "
  • Like
Reactions: wtp
SteveSimpkin
Lancaster, CA
From the above information it appears that the Moline PD and Fire/EMS are on an EDACS analog trunking system.
If this is the case and cost is an issue, the Uniden BCT15X base scanner should be able to pick up that system. These sell new for about $150 and can be easily programmed using FreeScan software, the included serial cable and a subscription to RadioReference. Unfortunately Uniden no longer makes an inexpensive analog trunking handheld scanner. In the used scanner market a Uniden BC346XT, BC246T, BCD396XT or BCD396T hand held models will also work. The last two will will also pickup up P25 Phase 1 digital systems.
AK9R
Super Moderator
Central Indiana
Since the OP is looking for an EDACS scanner, which is something an out-of-the-box Baofeng UV-5R can't decode, and since the OP has been referred to real scanners that might serve his needs, this thread is locked.
If the OP has other questions about scanners or receiving the Moline PD, I suggest he post them in the General Scanning forum or the Iowa forum.
