fulfordr
I have a Parrot hands free cellular telephone setup that uses a thru the glass antenna. I recently purchased a Radio Shack multi frequency thru the glass antenna that I plan to use with my BCD996XT scanner. How close to the cellular antenna can I mount the Radio Shack thru the glass antenna. The instructions in the Radio Shack antenna just say to mount it 1 1/2 inch from the edge of the glass. Would there be any intereference from the cellular antenna if I mounted it beside it, 1 1/2 inch away for it and the edge of the glass?
My other option is to go to the other side of the vehicle where a Larsen thru the glass tranciever antenna is mounted that is no longer in use. I had thought of moving the Radio Shack antenna to the outside portion of the Larsen antenna as it will screw onto the mount. Then taking off the inside portion of the Larsen and replacing it with the Radio Shack box with antenna lead that comes with the Radio Shack multi frequency antenna. The Larsen antenna was used on a 450.000 type business radio and I dont know if the inside window portion is loaded for that or not. I dont know if the Radio Shack inside portion is loaded somehow for multi band either. Any info on this would be appreicated. Sorry for the long post...
