CanesFan95
Seems like anytime I've listen to something conventional on a ham rig, you get better reception/signal strength than on a scanner with comparable antennas in the same location. How come?
I would guess it is because the ham radio you are using is built to cover a small portion of the VHF/UHF spectrum where a scanner needs to be wide enough to cover typically from 25MHz to 1300MHz.
The Ham Radio is tuned and built to primarily cover the VHF and UHF Ham spectrum. That is its only job (unless there is some out of band reception.)
Like hum incessantly, and fail with cold solder joints and broken battery door clips? Couldn't resist, but...there is truth to that as to why people choose commercial radios. I also prefer a radio that does one thing extraordinarily well, instead of one that tries to do everything with varying success.The Unidens will also do things that none of the Unications or professional 2-way radios will do.
I doubt it. Do they cover ~25 MHz to ~ 1GHz with pretty much no gaps? They only do teeny tiny slices of 700. No UHF milair, and so on. So their coverage is nothing like most scanners.That's actually not it at all. An APX8000 or a Harris Unity XG-100P covers VHF, UHF, 700 MHz and 800 MHz just like a 'top of the line' consumer-grade scanner
Hm, I don't think the OP's question has anything to do with simulcast.
Look in the mirror. Only one post in this entire thread has even a vague resemblance to what you just said.It doesn't. His question was answered in post #2.
What we see in the posts that follow, is the typical tunnel vision of the 'spurts that populate RR.
Everything is a "simulcast" issue that only the SDS's can fix.
Not everything is simulcast like 'those supposedly in the know' believe. I have used my ham radios for decades as scanners because they work better than any scanner I have, or have owned on conventional analog frequencies.
There is a poster in one of the forums that sold his digital scanners and got two analog conventional scanners with money left over.
Take the blinders off 'spurts, and read what posters are actually saying. Stop with the kangaroo mindset. It's become a trend that is hurting this website.
How Come Ham Radios Receieve Better Than Scanners?
So when I saw majoco's reply and it said exactly what I was going to say. All I could do was like it. No disrespect to any other reply of those I know and respect but...
Simple answer - because they cost a lot more.
That's actually happening now with shipping costs back to the repair center.Or maybe if you pay one price but find it doesn't receive well enough for you, you could send in a few hundred dollars more so that your scanner will start working better.
The thread explains the difference in performance between scanners and professional gear, that are not only related to simulcast but to general reception quality.Hm, I don't think the OP's question has anything to do with simulcast.
