No, it did not change anythingHere is a reply I got from Whistler some time ago:
Thank you, we have found some bugs on some Win 10 machines and are working to correct these.
In the meantime please try the following and let me know if it fixes some of your issues.
Right click on the shortcut and select Properties > Compatibility > and under settings check the box for Override high DPI scaling behavior, then select System in the drop down box and hit Apply.
Thanks but I found no help thereTry this...or read through that thread for suggestions
02/18/18 New PC app today - Win 10 improvements
If you have already downloaded and installed the EZ Scan application from the whistlergroup.com website as of 2/6/18, please update to the latest release using the pc app > Check for PC Application Updates. This will address many of the compatibility issues of the newly complied application...forums.radioreference.com
I tried that. No changeTry it again but make sure you click on a step TVEngr did not mention.
Right click on the shortcut and select Properties > Compatibility > Change high DPI settings and under settings check the box for Override high DPI scaling behavior, then select System in the drop down box and hit Apply.
It is a scaling issue because your PC has a high resolution screen and that causes ezscan to get reduced in size...you have to change the scaling...google windows scaling for solutions and make sure you're running the latest version of ezscan.I tried that. No change
I am running version 3.40It is a scaling issue because your PC has a high resolution screen and that causes ezscan to get reduced in size...you have to change the scaling...google windows scaling for solutions and make sure you're running the latest version of ezscan.
You're doing it wrong, you do not change the scaling for the laptop, you change it for ezscan only via properties and compatibility mode as described in a earlier post.I am running version 3.40
Changing the scaling to the largest option does not help, and just makes everything else on the machine to big to use.
I guess I should word this differently. I dont just want the font bigger, I want the program to use the entire screen, not just be tucked into the upper left corner if that makes sense.
I could remote in via chrome remote desktop, set it up then PM me.I have tried and tried. I followed everyone's instructions and I get the same results.
Thanks everyone but it just doesnt change anything.
If there are any teamviewer users who would like to remote in and try i would be happy to give that a shot
Wackyracer remoted in and fixed it.
