How do I copy only 1 bank vs using win96 to send someone?
ripperq2
How do I copy 1 bank using win96 to send instead of my entire .p96
files?Also is there a way to program single banks using win96 and
updating just those certain banks or do I have to let win96 upload
the entire scanner banks? Thanks :D Thanks all!
AZScanner
Somewhere in this room. Right now, you're very col
Re: How do I copy only 1 bank vs using win96 to send someone
Actually, this is really easy to do.
In Win96, open your file that contains the data you want to send, then select Export from the file menu. Enter a filename and make sure the export type is CSV.
Next, in the dialog box that pops up, select the checkboxes that correlate to the data you want to export. Then click OK. You will now have a nice little CSV file to send to your friend.
Tell your friend to use File->Import to extract the data from the CSV file. I recommend importing it into a blank template so your friend can then copy it to whatever bank they choose.
-AZ
