How do I enable FPP on HT1550XLS W/Red Battery??
IAmSixNine
Dallas, TX
Its an option in the software you have to enable.
once its enabled, each personality has to be enabled for FPP option, then you go into the menu on the radio and select radio edit, put in the code you assigned in the main section and your off and FPP ing your radio.
I did this to a few of my radios a while back so this is from memory.
idle00955
Manch NH
i believe it is in the cps active and the passcode is 0000 but i dont see it int he options anywere.
Seadoo
FPP is an option that needs to be enabled in the Flashcode of the radio. Once that is done, you can FPP your radio.
drdog
Chicago
WRONG !!! Seadoo!!!
You are thinking of the XTS/XTL Series of radios. On The HT1550XLS the FPP is not activated by a flash but by the software and the special Red FPP battery. Seadoo, Read up first, before throwing in senseless answers which are of no use to anyone... ( without the Red FPP battery you can "Flashcode" till you turn blue in the face and the radio will not work FPP!)
CommJunkie
FN20jf
FPP is not enabled in CPS or Flash, but "EDIT MODE" is. You need to make sure in CPS it's checked as a menu option in the radio.
CommJunkie
FN20jf
UGH! Another dead topic from 2 years ago.
I really gotta check the dates more.
KCrADIOgEEK
Kansas City Metro
THANK YOU "radioman2001"
Maybe old but still applicable when people are using the search. With the RED battery, each channel must be enabled for FPP. In the Options tab for each frequency the EDIT box must be checked.
Thank you for the info here... I would have never been able to get anywhere until I saw this post about the
EDIT checkbox... Don't forget to set your password in the "Radio configuration - EDIT MODE" tab as well...
THANK YOU!
THANK YOU!
THANK YOU! radioman2001
