How do I get ahold of a commercial Motorola APCO25 mobil ant
dizwiz
Im having antenna issues for mobile monitoring of Ohios APCO25 MARCS system.
Id like to get a hold of a commercial MARCS mobile antenna to mount on my car. Im hoping it has a BNC connector on it too.
I know antenna design is complex and im sure the guys at Motorola have their antenna design ironed out and optimized for MARCS.
Any idea how I could get one?
Id contact Motorola, but I dont know what the radios are called...
K5MAR
Stillwater, OK
You want to ask for antenna for the specific freqs that are being used. The only optimization done is tuning the antenna with an RF wattmeter after it is installed. That is done by the installer. APCO P-25 is a form of modulation, and in itself has no effect on the antenna.
Mark S.
Cmcadet
Fort Worth TX
You really just need a Motorola radio. Then you won't have any antenna problems. If their system is 800 MHz, any 800 antenna will work, same goes for any band (vhf/UHF). The problem with digital is the error correction while you are moving. The Motorola radio is built to handle the mobile environment however the scanner isn't built as well. Try driving around until you have a problem with reception, stop in that spot and sit still. If you still have a problem hearing it may be a coverage issue.
If you need an antenna I would recommend one from here:
http://shop.waltel.com/catalog/index.php/cPath/10_12
I just bought a 1/4 wave VHF antenna from Waltel and it is probably the best antenna I have had on my vehicle for VHF stuff.
Good luck.
