How do I install freqs in other scan lists?
fmaples
Granger, IN
How do I get my ARC 500 software to install my freqs into a different scan list? It always goes to sl 1 and overwrites all other entry's. I tried checking box sl 2 to upload but it still goes into sl 1. Also how can I add other freqs to a sl without deleting the entire list which has happened every time I tried to put in a new freq. Does it have to be selected in the global menu on the scanner first, or can I select it from the software? Thanks for any help. Using the GRE 500.
Butelsoftware
Dayton Hamvention 2019
Every object has a scanlist setting, default is 1 but you can select any SL in that column,
You can not add data to the scanner, this is a limitation of the scanner. To add data first read from scanner in the ARC500 software, add the new data and then upload to the scanner.
Gommert
Butel Software
