How do I program a BC700A?
G
Guest
Guest
I have a Uniden BC700A without a user's manual. Can anyone help me on how to program my local frequencies into a scan list. Thanks.
TippeTrunker2
Lafayette, Indiana
BC-700A Programing and Manual
npd_66,
I have successfully programed BC-700A's using the instructions for
a BC-350. They are vitrually the same radio, except the 700 has
800 Mhz capability. The manual for the BC-350 is available on the
Uniden site.
Dan
TippeTrunker2
Lafayette, Indiana
npd_66,
a BC-300A. They are vitrually the same radio, except the 700 has
800 Mhz capability. The manual for the BC-300A is available on the
Uniden manual site.
:oops: My previous reference to the BC-350 won't work.
Dan
pro92b
Mutated Member
I'm not familiar with the BC300A - do you have a link to the manual?
Uniden did produce a BC350A which was similar to the BC700. A PDF manual is on the Uniden site. Radio Shack sold a radio very similar to the BC700, the PRO-2038. They have text instructions on site, no PDF manual.
pro92b
Mutated Member
Well yes, that's the BC350A I referred to. You mentioned a BC300A, a model I am not familiar with.
TippeTrunker2
Lafayette, Indiana
I gave my internet copy of the manual to the last person I programed one
for. The book was from a version of the BC-350A that was sold in Europe.
It had different model numbers, but it was the same scanner. The book
even had the 800 MHz specs. I asked the owner to bring me the book,
and I'll try to get the web page for it. The BC-350A book should work for
everything except it's missing any reference to the 800 Mhz. Lots of info
on out-of-band conversion on the BC-700A, a simple google brings up
about 9 pages.
Dan
npd_66
:D Thanks for the help. I looked on Uniden's website and tried several different models and none of them seemed to work. I believe the BC300 or the BC350 are the correct instructions for the BC700A that I have but I haven't been able to get them to work yet. When I turn on my scanner it also says "memory loss" in the lower right corner of my display. Would this have anything to do with my problem and how can I get it to go away? Thanks in advance for anyone's help!
duckbird
Texas
Programming information the BC700A
Adding frequencies to the Private Bank
1. Press Search
2. Press Band to locate the frequency band
3. Press Hold when you get close to the frequency you want. Then using the Up or Down key locate the exact frequency.
4. Press Program
5. Press Private
6. To locate the channel you want press the Up or Down key
7. Once you locate the channel, press program.
