How do i program my Pro 106 to chesapeake
Vagoodolboy
East Coast VA
I have tried a lot of times to program my pro 106 to pick up Chesapeake but i get no audio. I have tried programing it under PRO 25 Mot 800/900 Mot VHF/UHF nothing is working the idd come up but no sound? The Chesapeake system is
System Type: Motorola Type II SmartZone
System Voice: Analog and APCO-25 Common Air Interface
Spitfire8520
I might be completely clueless! =)
Colorado
You need to program it as a MOT800/900 system, then you need to scroll all the way to the bottom until you see a menu that says T Tables:. Set it to Custom, then hit SEL/ENT to set up custom tables.
Set the tables as follows:
Code:
Table 01:
  Low Chan: 440
  Hi Chan: 559
  Offset: 440
  Base: 851.02500
  Step: 25.000
Table 02
  Low Chan: 0
  High Chan: 719
  Offset: 0
  Base: 851.01250
  Step: 25.000
Save everything and it should work if you have all the control channels and talkgroups programmed in correctly
