How do I setup on my Bearcat scanners
DJ88
Brick Twp., New Jersey
Thought maybe I could help you, but I have a BC785D and I don't know if they program the same way or not.
Basically what you have to do is select a bank and set it for Trunked. Then enter the frequencies for the system. With mine you don't have enter Text Tags for the frequencies because when the frequencies appear on the screen you don't see the tag information.
After you get the frequencies in you will enter the talk group ID numbers for the talk groups you want to listen to. You will want to put the text tags in for the talk groups as they will appear on the screen when the active talk group ID appears. Also make sure the unit is in the ID SCAN mode. That way you will hear only the Talk Groups you have programmed in. If it is in the ID SEARCH mode, you will hear all actrive Talk Groups in the system whether or not you programmed them. It tells you how to put the unit in the different modes in the manual.
Motorola Type systems are the easiest to program because all you need are the frequencies and talk groups. No fleet maps, base, or offset frequencies or spacing.
In your manual go to the Trunking section and it will explain what you have to do when entering the frequencies. Then there should be another section about Talk Group ID Tags that explains how to do that. You may have to read it a couple of times if you're not familiar with trunking. Just take it slow, one step at a time. When I did mine, I had never programmed any trunked systems before and figured it out. If you have a problem email me. Just click "EMAIL" on my post and send your message and I'll try to help you there, rather than take up a lot of space here. I'd be more than happy to take the time to do it if you have a problem.
njscanmaster
Ridgefield NJ
Here is all the Info I have can you HELP ?
I have the BC785 D too
Public Service Electric & Gas Co. (PSE&G) System
Various, NJ
System Name: Public Service Electric & Gas Co. (PSE&G)
County: 9 counties
System Type: Motorola Type II Smartnet
System Voice: Analog
Sysid: 272C
CT: 138.46
Last Updated: 03-11-04 00:38 Changed Site-001
Hits: 1280
Latest News Update Posted on 06-20-02 21:35
10 site Simulcast System
Locations: (FCC License WNIT313)
Lawrence Twp - Mercer County
South Brunswick - Middlesex County
Edison - Middlesex County
West Deptford Twp - Gloucester County
Moorestown - Burlington County
Bordentown - Burlington County
(FCC License WNIT315)
Fort Lee - Bergen County
Hillsborough Twp - Somerset County
West Orange - Essex County
Wayne - Passaic County
Click Here to Display All Past News Updates (2 Total)
Misc System Information
Telephone Interconnect can be heard on:
938.8875, 938.900 and 938.9125
System Frequencies
Red* are Primary Control Channels, Blue* are alternate control channels
Site Description Freqs
001 10 Site Simulcast 937.3875 937.4000 937.4125 937.4250 937.4375 937.4500 937.4625 937.4750 937.4875
937.5000 938.8875 938.9000 938.9125 938.9250 938.9375 938.9500 938.9625* 938.9750*
938.9875* 939.0000*
002 PSEG POWER NJ (NBU) 935.9750 936.9750 937.9125 937.9625 938.3875
System Talkgroups
Updated in the last 7 days Updated in the last 24 hours List All in one table
Electric - North Talkgroups
DEC HEX Description
1552 061 Electric North - Bergen & Hudson (Palisades Division)
1584 063 Electric North - Hudson County
2064 081 Electric North - Essex
2096 083 Electric North - Essex
2128 085 Electric North
2160 087 Electric North - Clifton Area
2192 089 Electric North
Electric - Central Talkgroups
DEC HEX Description
2576 0a1 Electric Central - Middlesex County
2608 0a3 Electric Central - Somerset County
2672 0a7 Electric Central - Middlesex County
Electric - South Talkgroups
DEC HEX Description
3632 0e3 Electric South
3664 0e5 Electric South - Burlington (Southern Division)
3696 0e7 Electric South - Western Burlington County
3792 0ed Electric South
4016 0fb Electric South - Burlington (Southern Division)
Gas Talkgroups
DEC HEX Description
2288 08f Gas North - Newark
3088 0c1 Gas North - Bergen
6480 195 Gas Central - Middlesex
7952 1f1 Gas Central - Mercer
Generation Talkgroups
DEC HEX Description
48 003 Burlington Generating Station
336 015 Essex Generating Station
432 01b Linden Generating Station
Miscellaneous Talkgroups
DEC HEX Description
2640 0a5 Appliance/Heating Repair Central/North
4368 111 Passaic County
17840 45b Phone Patch?
Data Talkgroups
DEC HEX Description
4848 12f MDT
24800 60e MDT
nosoup4u
High Bridge, NJ
The newer Unidens actually have a 900Mhz trunk option. He should select that if he has also. I have also found that you need to put the 900Mhz freq's in NFM mode, otherwise the audio and reception isn't too good.
