SDS100/SDS200: how do I turn on recording function/listen to recordings
llwade
Chillicothe Illinois
I have a SDS100 scanner.
How do I turn RECORD on
( once recorded ) How do I select a specific TG to listen to
thank you for your time
bravo14
Polk County FL
Fun+Replay.Record
Specific TG if you sit on that TG yes it will record the tg as you sit on it. Now if you are scanning it will record everything it does not record certain tg.
ofd8001
Louisville, KY
It's probably the most cumbersome, thought I know of no other way. Download the recordings from the SD card to a computer, then use Windows explorer to get to the recordings. "When you arrive" sort all the recordings using the "Title" column, which is the the one associated with talkgroups.
dfw1193
Venus, Texas
Also create a shortcut to get to the folder where you copy the wav files. I now have 1 shortcur for each folder I copy the .wav recordings to for each scanner if i am keeping any i move it to another created sub folder named by the date and/or topic.
