How does close call work?
noaim
Milwaukee, WI
Does it simply scan all available frequencies or how does it work?
Sent from my iPad using Tapatalk Pro
Ubbe
Stockholm, Sweden
It used to be a seperate IC that was a complete frequency counter that you could buy for $5. Probably the same in Unidens latest scanners. They are not so sensitive and needs a clean signal to be able to count a frequency. That's why Uniden says youi'll need to have 15-20dB difference between the signal and other RF sources.
I guess they open up all antenna frequency filters at the same time, the ones you specify in the closecall configuration, when they check if they get a steady count from the IC chip. You will get a huge increase in range if you put a narrow filter between antenna and scanner but only a FM broadcast filter will also help a lot. Any extra filtering outside of the frequencies you plan to closecall will improve its performance.
/Ubbe
