how far can you hear
landlord2see
callao ,va
i live in the northern neck of va and i am a big scanner listener i love to hear other counties i can listen to york and even into maryland .is that normal for a handheld rs pro 99?
br0adband
Springfield MO
Depends on the antenna, really. If you're doing all that monitoring on the stock ducky antenna for that scanner you're doing well.
Trees, buildings, houses, all of it contributes to how much you hear but nothing matters more than the antenna you use and how high that antenna is off the ground.
On the stock ducky from inside my home in Portsmouth, VA, I can pick up the Yorktown Naval Weapons Station which is maybe 65 miles line of sight from where I'm sitting, so that's pretty good for me. If I had an outdoor antenna (and someday I will) I'll more than likely hear a lot more than I am right now.
Sounds like you're doing fine, but if you can get an outdoor antenna mounted high up on your roof or possibly out a second floor window, it's like an entirely new world of stuff to pick up.
Good luck,
Paul
tglendye
Blue Ridge Mountains, Shenandoah River- VA
Another thing it depends on is the transmitter's power and antenna. If they have a low output for example, the signal won't transmit far. An antenna mounted high on a mountain top with a powerful transmitter will usually transmit very far.
Every once in a while I hear PW, Loudon and DC traffic (I live in fairfax) but for the most part its garbaled. I use to run the stock bearcat antenna but I recently swiched to the radio shack 800mhz one and I noticed a big difference.
-Wes
