Baofeng How I do? With Baofeng uv-5r
Ndrew133
Mont-Carmel,Qc
Hi everybody! I want e know what can I do with my Baofeng uv-5r ? I try to make scan
And never I find e channel with somebody speak please someone give me some help and explication
vagrant
ker-muhj-uhn
California
A Baofeng is a low grade transceiver. I recommend you purchase a “scanner”. Perhaps something like a Uniden BCT125AT, or a scanner suited for your location and what you want to monitor.
Well I just noticed the sub forum this is in, so I recommend you use Repeaterbook. In the USA we also have amateur coordinating groups that post repeaters on their respective websites. You can then use that to program those frequencies into your Baofeng, but just use whatever local coordinating body you may have in Canada. Even then, those repeaters may be offline permanently.
There is also 146.520 MHz for simplex. Still, your handheld radio may not receive simplex too often unless the other operator is nearby.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Salut et bienvenue sur le site!
La première chose que je te recommanderais c'est de rejoindre un groupe radio amateur local. Ces gens-la, ils peuvent te renseigner vers la bonne direction concernant les activités radio qui doivent être autorisées et les activités que tu peut faire sans un permis ou licence - moé, j'connais pas toutes les lois canadiennes--c'est différent icitte aux Etats-Unis.
Bonne chance--on se verrons temps-tôt sur les ondes!
Meterorite
Earth
I downloaded chirp, cloned the radio, searched for local repeaters, populated a list of them, and saved them to the radio. A bit of a learning curve, but tutorials can be found on YT.
Chirp:
I hope this helps and good luck!
