Depends on the air-show envronment
The standard Uniden duck is resonant at 155 mhz or so. That makes it really inefficient if you are trying to monitor military air centered around 300 mhz - even if you are pretty much close to the aircraft.
Type of airshow? Low key general aviation, or fully-blown military base show?
One problem you may face at a show is desense. I'd invest in a ** smaller ** antenna like a Comet CHA-32 miracle-baby (bnc or sma).
Example: The air boss at a low-key show is only a few hundred feet away from you in your fold-out chair. He is on VHF. Yet you are trying to tune in the military aircraft directly, and as soon as the air-boss transmits, your scanner is desensed by having too MUCH antenna, and you never hear the military planes - at least the ones he's not talking to directly.
Naval airshow on the coast, during inclement weather? You may also be facing radar noise - even though it is not in the range our scanners can hear. Ever see a shipboard video cam plagued by radar noise? Same effect. Using a smaller antenna when you are so close to the action is usually recommended.
This is why some "racing scanners" also include a very small duck. Nearby racing infrastructure radios can desense the scanner. It isn't just a matter of smaller convenience. Same thing with airshows.
Low key general aviation airshows can be less demanding. But still, surrounding infrastructure radios can sometimes desense the scanner too.
In a VHF only environment, you may want to bring an inline airband bandpass filter, like the AOR ABF128 to between the scanner and the duck - whatever you bring.
Too much info I guess.
Try the oem duck - use attenuation on a nearby airboss if you have to, bring along a smaller duck too - and for vhf only, maybe bring along the inline filter.
EARBUDS - don't drive your audio into distortion. Use in-ear buds that fit nicely into the ear canal. Forget trying to listen to the scanner speaker at the fence with ANY handheld scanner for any length of time - too low powered, hissy nasal fidelity (from ALL manufacturers) and such make you drive it into distortion. You either get tired of listening to it quickly, or have moved so far from the action to hear it that the show is less fun.
Don't skimp on getting *quality* buds. Get those designed for communications, NOT high-end music fidelity! The hi-fidelity buds with their high-frequency response also accentuate the generally poor scanner audio that is hissy and high-frequency. You don't need much beyond 3khz for radio comms. More than this and listener-fatigue sets in.
Again, sorry about the info overload, but sounds like you may want to get a good jump into airshows from the start!
