I'll bet that I've owned over 50 scanners over the past 35 years. Only two scanners have developed problems such that I got rid of them. I used to have a Uniden Bearcat 800XLT desktop scanner which was bad to overheat, and when I sold it (1999 or 2000) the display was going very dim. The other was a Radio Shack Pro-96 what started going deaf on 800 MHz about twelve years after I'd bought it.
Currently my oldest scanner is a Uniden 142XLT ten channel base scanner manufactured in 1990. It still works great; I've modded it with a discriminator tap and and it's what I was using for monitoring DMR and NXDN frequencies (connected with a computer running DSD+) until those modes became available on the most recent scanners.
This sucks. I spent hours getting the BNC soldered to the 102" whip.Be careful with a longer antenna. It can put stress on the connector and cause failure of the solder joint inside the radio.
Use bigger torch!This sucks. I spent hours getting the BNC soldered to the 102" whip.
Getting a better antenna is rarely a bad idea unless you live in a city and a better antenna may cause more interference depending on the selectivity of your particular model which varied widely back then. GRE were always better than Uniden back in the RAT Shack days. I think the PRO 64 to me looks like a GRE model so go for it! I reread your post and the 6AA confirms it to me being GRE as Uniden never had a 6 cell FWIK. Rubber Ducks back then were often awful.I guess I have 2 questions. My first is that I have a old Radioshack Pro-64 that must be at least 15 years old. The ac adapter broke so I just use 6 re-chargable batteries. I listen to it quite a bit. Am I just lucky to have mine last this long? Granted, I never take it outside my home. Also, would getting a telescopic antenna help to replace my "rubber ducky" one give clearer reception? I live in Chicago and mainly just listen to their 15 zones. It is very, very busy. Thank you for any responses.
Depends on the design of the radio. The connector is actually fused into the body of the radio in some way or another pretty solidly even on plastic radios so long as you don't put something ridiculous on you'll be fine. Even still it's one of the easiest things to repair since it's just basic soldering. I've swapped SMAs to BNC the same way before.Be careful with a longer antenna. It can put stress on the connector and cause failure of the solder joint inside the radio.
Right on, I have a Pro-22 with a big collection of crystals I've accumulated for it some of which I've regrinded with this little kit I have. I have all the good frequencies I want now.I have my realistic Pro 2021 from the 1980s still works great never had any problems with it. I listen to it daily.
Yes, retract or remove it when not in use so in the event the radio tips over no damage will be done to connector nor antennaBe careful with a longer antenna. It can put stress on the connector and cause failure of the solder joint inside the radio.
How about recapping? Are they all still using the original capacitors too?I still have every scanner I've ever owned, and they all work. I've certainly had to repair a few keypads and connections between BNC & circuit boards though. Issues that diminish their lives include: (over)charging batteries in the unit, using the antenna as a handle, dropping them, and extreme use (although that would wear out a base model just the same).
When it comes to capacitors, yes they are original. Funny you should ask because I have some fairly new electronics (TV tuner, DVR) that were built in China and failed because of capacitors. I replaced all of the caps in those units and they are back up.How about recapping? Are they all still using the original capacitors too?
did you lock it up? I think you can download a manual? Ive taken them apart and sprayed contac cleaner on the contac pads.The buttons on my Pro-64 don't work any more. I forgot when I bought it. I just want to program some analog fire dispatch, marine, railroad and aircraft frequencies into it.
I don't think a Pro-64 will work to listen to those areas in Indiana, Lake County Indiana is on a P25 Phase II system, most everything is now on it, if you are wanting to listen to public safety.Thanks everyone. I was considering getting a new model but think I will stick with this one and try a new antenna maybe to pick up East Chicago, Gary IN, Hammond IN area.
