prcguy
A circulator can give about 35dB of isolation and in a marine radar there is always a limiter of some kind in front of the receiver to reflect or absorb the left over transmit power so it doesn't damage the receiver. PIN diodes can be used up to a certain power level as a very fast T/R switch but you need a high voltage like -100v or more to bias the diodes in a high power environment.
A semiconductor switch works at nearly the speed of light - the delay comes from the actuating circuit. I don't know what you are doing bit maybe a circulator might be an alternative, depending on what you're doing?
Think about radar - Kilo/MEGAWatt power going out as a pulse, isolated from the receiver expecting microVolts back! Pulse repetition can vary a lot, but the receiver needs to be activated immediately the pulse has gone out, and minimum range for some radars is a few miles - that's a very short time!
