How to add SLR5500 repeater to PRTG
salarazad
Hi Everybody!
We are using SLR5500 repeaters, and we are looking for a way to add the SLR500 device to PRTG monitoring software.
Does the SLR5500 repeater support SNMP protocol? and how it would be possible to achieve this task?
Thank you!
Firebuff880
Boynton Beach, FL
If your are running a Cap Max system then you can, but the MIBS come through the SA task on the CMSS and you need a license for the North Bound interface to do anything with them.
Otherwise the answer is NO. The repeater speaks in the RDAC protocol and you need a licensed service to get that and pass it to something like PRTG. Although you can do a few simple things like PING tests to see if the repeater is up or down.
Our application solution includes RDAC monitoring and alerting under a number of conditions. PM me if you are interested. You might also look at GW3.
salarazad
We are using a conventional repeater site with IP connection, so it is not IP Site Connect system or Capacity Max system.
But the repeater has an IP address so in theory, we should be able to add it PRTG? or it does not support the protocols supported by PRTG?
SteveSimpkin
Lancaster, CA
Try pinging it from the computer running PRTG. If the repeater responds to the ping then at a bare minimum you could add it to PRTG as a Device with a Ping Sensor as Firebuff880 suggested. After it is added run an Auto-Discovery or Recommend Now on it from PRTG to see if it will find additional Sensors. Even if you only have a Ping Sensor, at least you would know if the repeater is on and functioning over the network. You would also have a record of its uptime.
salarazad
We have added a ping sensor on PRTG", its working fine. but we couldn't find any other sensor to see the temperature, power and other details of the repeater.
What are the protocols that the SLR repeater supports in general?
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
It only supports a proprietary protocol. You use a program called RDAC to connect to the repeater and view the alarms. If you want some sort of interface, you are looking at a DApage solution or a GW3 solution. TT
