I have read all the manuals I could find about Uniden BCD536HP and I have not as yet found instructions on how to change any of the eight custom service slots. I am sure there must a simpl
-I could not find any information in the manuals. I find it hard to believe that they would put eight custom slots there and not have a way to edit them.
-I expect you would only like to change the names “Custom 5” to whatever alpha-numeric you would like... NOT the titles of the numerous Service Types.
I tried and was successful changing “Custom 5” on my SDS200 to now read “2 Meters Ham Band” using the steps I gave you. I believe the BCD536HP and my SDS200 use the same menu structure for the most part.
-I have not as yet found instructions on how to change any of the
You are correct in what I gave the OP. I figured he got mixed up with the terminology and wanted to change “Custom Search” names. If he was actually after the “Service Types” names, which are hard coded, I wonder why? His meaning is lost on me… any ideas?-
I believe the OP is talking about the names of the "Service Types",
There are 8 custom "Service Types". Those custom service types, 1 through 8, can not be changed.
The instructions you gave him are for changing the names of the "Custom Searches". There are ten "Custom Search" names, 0 through 9, that can be changed.
Thanks Does not make sense, but ok.
You write;
“If you mean "Can I change 'Custom 1' to something like 'Texas 91' ", no that cannot be done. It is a function of the database/firmware.”
Incorrect. All the Custom search slots are editable. (Custom 1, 2, etc). It’s the “Service Types” (Fire Dispatch, Fire Tac, etc.) that you can NOT change.
But then you go on to describe why you can’t and I see nothing wrong with that… as long as we are talking about Service Types.
