How to close Siren app on iphone
N8TXX
Scanner Enthusiast
S.E. Michigan
I realize the siren app has been abolished, but thought I'd give it a try on my 536HP. It seems to be working well, but I'll be darned if I can figure out how to close the app?
noaim
Milwaukee, WI
Double click home button and then swipe it up in app switcher if you have a xs then swipe up and hold to open app switcher
Sent from my iPhone
N8TXX
Scanner Enthusiast
S.E. Michigan
I have an "X". Swiping up or down does nothing? I know I can power down the phone, but should be an easier way?
Can someone please try that has an iPhone X?
noaim
Milwaukee, WI
The Xs and x are the same start at bottom swipe up to middle and hold that’s how you bring up app switcher
Like swipe and hold your finger in middle without taking it off screen
Switch apps on your iPhone, iPad, or iPod touch
Once you get to the app switcher swipe the application you want to close up
Sent from my iPad using Tapatalk Pro
N8TXX
Scanner Enthusiast
S.E. Michigan
I know that’s how it’s supposed to work, all my other apps work by swiping, but not Siren. Did you try to close Siren on your X?
ofd8001
Louisville, KY
I find that I need to hold the iPhone (XS) horizontally before I can do the swipe up thing. It is a change from the way it used to be with my iPhone 6. It's more of an iPhone issue than an app issue.
noaim
Milwaukee, WI
You have to swipe where the line is on the iPhone
noaim
Milwaukee, WI
Now I understand why he’s stuck you need to swipe from the bottom of the application so if it’s Horizontal It changes where you need to swipe from
N8TXX
Scanner Enthusiast
S.E. Michigan
Got it! I was swiping in the vertical position. I found the line in the horizontal position.
Thanks!
