I've got rdio-scanner setup and working great. I can connect to it from the pc that runs it and from my phone as long as I'm connected to same network that the pc is on. As soon as the phone connects via cellular data I lose connetion. I've got an exception in my router for the ip and port that the program uses. I also have a no-ip account setup to redirect to it from a dynamic link. Any suggestions?
You can do that easily and for free using ProScan's RadioFeed Source Client and Web Server Audio Streamer!
ProScan.org
RadioFeed Features
Source Client - Streams real time audio to Broadcastify, Icecast, and ShoutCast servers. Source Client can replace Edcast/Oddcast and SimpleCast types of programs. If you are a Broadcastify stream provider then the Source Client can be configured automatically.
Web Server - Servers a web page and serves real time audio and folders / files. Audio and folders / files can be password protected.
Audio - Low latency.
Audio Flow Diagram - Shows audio flow along with the volume controls and level meters.
Metadata Source - Text tags can come from other programs, scanners, and files. Supports 36 different scanner models.
Statistics - Shows peak and current listeners, bytes transmitted/received, and up time.
Status Logging - Shows connections and errors.
Performance - Low CPU and memory utilization.
Tabbed Layout - Makes the program look clean and organized.
ProScan.org
