UFEMTFF said:I currently only have one system programmed with 10 talkgroups on ID scan. I would like it to continue to scan all of the talk groups, but make it so that one TGhas priority over the others. Is this possible?
Are there any scanners that do this, or is it impossible on any due to the way trunking works?mdulrich said:No it is not.
Mike
UFEMTFF said:Are there any scanners that do this, or is it impossible on any due to the way trunking works?
Setting Priority Talkgroups (Motorola and EDACS only)
Talkgroup priority works slightly different than conventional priority. With talkgroup priority,
the priority talkgroups are only checked when the scanner is on the control channel. So, if
you have delay turned on for the system or are holding on an ID, the scanner will
immediately switch to the priority talkgroup if it becomes active during the delay or while
there is no transmission on the held talkgroup.
To assign a talkgroup as the priority talkgroup, select it in Scan Hold mode (see “Holding on
a Single Talkgroup”). Then, press and hold PRI for 2 seconds.
Kirk said:It's not theoretically impossible, but there are no scanners currently that can do that. You'd need multiple radio receivers to accomplish this goal.
