I've been using my R30 for a while now, but can't figure out how to decode the P25 frequencies used my area. I live in Southern Utah and my trunking scanners pick them just fine, but when I create a P-Scan edge range w/ the base freq of 851.250 - 859.000 using 25Khz spacing using the P25 mode and scan the range the radio stops on certain frequencies and there's a signal there, but there's nothing decoded and no audio then it continues scanning. I don't understand this unless they're phase-2 signals. If I manually plug some of the 800mhz freq into the receiver say 851.837 using FM mode I can hear some of the channels fine. So, I guess my question is, why doesn't the P25 decoding work? is it because my area is not using the P25 encoding or maybe it's phase-2, or maybe there's something wrong w/ the receiver, don't know.
If I look at the RR settings here Utah Communications Authority Trunking System, Various, Multi-State - Scanner Frequencies for my area it says the base freq is 851.250 w/ a connect tone of 138.46. I'm not sure how the connect tone works with the R30 since you can't use tones in P25, at least I don't think you can.
Anyway, can anyone shed light on this topic since I haven't found any videos of anyone setting up the P25 mode on the R20 or R30 just videos of others showing how great it is =)
