How to delay a feed
adacats
Scanner and Train Nerd
South Euclid, OH
I have a feed on broadcastify, but i want to put it on a website for the public to listen. The problem is I want is delayed by a few minutes so that local authorities are ok with it. How would i go about doing this? It would be nice if I could have a delayed and non delayed feed since i listen to the feed as well, i know thats asking alot but is there any way to do this?
Thanks!
davenlr
North Little Rock, Ar
Could feed the audio into a DVR, and pause the dvr for the time you want the delay, then hit play.
Should work with an unsubscribed Tivo, which can be picked up fairly cheaply. You might have to supply a static video signal to keep it recording, however.
adacats
South Euclid, OH
Clarification on what i am trying to do, my computer already hosts 1 broadcastify feed. I want to keep the live feed for my use and those that help me run the twitter feed. I want to create a second broadcastify feed that is delayed a couple minutes for the general public, since that is what local authorities would like. Is there an easy way to do this?
n9mxq
Belvidere IL
Search Delay feed on the boards, you'll find it's only allowed on feeds from the agencies themselves. So, your second feed would not be allowed on Broadcastify.
I agree with the DVR idea, but you'd have to host it on your own website.
troymail
Silent Key
It's great to see feed providers considering delay as a compromise to avoid jurisdictions going to encryption.
These ideas need to be supported rather than shunned. Otherwise, the days of listening are numbered.
Perhaps delay like this should be applied across the board by default as a good faith solution.
As a enthusiast does it really matter if the feed is delayed a 5-10 minutes vs. permanently with encryption?
krokus
Southeastern Michigan
There should be some software method for accomplishing the delay. Since this would not be a common software, it would take some digging.
Sent via Tapatalk
INDY72
Indianapolis, IN
You will not be able to do a delayed feed on Broadcastify. Delay is not allowed. You would need to find another site to host the delayed feed, or set up your own site specifically for it.
There is a program out there called AudioDelay. Played with it a couple of time and seems to work well. Lindsey has stated the feeds have a bit of a delay in them anyway, but since it's for your own site then delay away!
blantonl
Founder and CEO
San Antonio, Whitefish, New Orleans
We don't allow delayed feeds on Broadcastify unless it comes directly from the official agency sponsoring the feed.
The reason is that there are too many confusing variables involved for the listeners which will cause major support issues for our staff in addition to archive issues. Archives are timestamped and would have to either be time shifted based on the delay or the listeners would have to take into account the delay when searching for an archive. Again, more confusion. And frankly, the archives are very valuable to supporting the business of broadcastify.
Implementing system-wide capabilities to delay feeds would be cost prohibitive as well. It would take an large amount of storage and resources to implement delays for even 25% of our 4000+ feeds. Delays would have to happen on the client (broadcaster) side.
We're sniffing around delay capabilities, but right now our official policy still stands --> No intentionally delayed feeds unless they are official feeds.
Thanks,
Sorry Lindsay for not correctly spelling your name, gettin old and the brain ain't what it used to be.
adacats
South Euclid, OH
So the radiodelay software works great, but i need to delay my feed by 10 minutes, as that is what police have requested. I have the ability to loop it through 2 instances of the radiodelay software, but that is it, and that still only gives me 6 minutes. Is there any version of the software or easy fix to extend the delay time. I am so close yet so far away.
blantonl
Founder and CEO
Kevin, be advised that you cannot implement delays on your feed to Broadcastify. If you willfully do so, you will need to find a new host for your feed or host it yourself.
adacats
South Euclid, OH
I am not implementing a delay on my feed hosted by RR, that one will remain live, I am hosting the delayed feed through mixlr.
webstar22
RenfrewCountyScanner.com
Ontario, Canada
Thanks!
Audio Delay - Delay Radio Broadcasts - Sychnronize TV and Radio
WDE, LLC: Products - SW based Digital Audio Delay
mdsxfire
EDBM
Uxbridge, north of the river Thames
So I know this is a really old thread, but has broadcastify looked at their policy on delaying feeds, if the encryption trend continues there will be no need for them or any other scanner feed sites
mikewazowski
Forums Manager
Oot and Aboot
You'd be better off asking your question in the Broadcastify Admin forum rather than bring a three year old thread back to life.
