Thayne said:
1. If you have 2 conventional scanners then scan the freqs you have conventionally, (Not the CC, but it shouln't change anyway).
With 2 scanners you can see the order in which channels become active and figure it out. When you think you have it right then program it correctly for trunking. Don't forget to always start at channel 1 in the bank.
If you don't seem to ever miss replies then you have it right.
2. Or you could run ETrunk on the control channel--
Hope this helps
First, make sure you have all the channels. Running Etrunk (if you can) will
give you a list of LCNs, but not the frequencies. Set up the channels in
conventional scan mode (at first). Watch the Etrunk display during a
quiet time, tracking a single user through each channel, noting the LCN.
If you can't run Etrunk:
If you have a PRO-92 or PRO-2067 (or can borrow one), park it on
the CC in manual mode (with channel set to ED). It will tell you the LCN
of the CC, even when idle. If the CC rotates, you can pick up several
LCNs from this.
One EDACS system I monitor assigns channels in ascending LCN
order. It used to be descending up until a few years ago. Some systems
might still be the latter. Wait for a quiet time a track a single user through
the frequencies. That will give you the order. Unfortunately, some systems
have missing LCNs so it may not completely work, and/or some channels
may be out of service at the time.
When you have the channels identified and programmed as EDACS, test
during quiet time by scanning conventionally on a second scanner, watching
the EDACS scanner. If you miss parts of the conversation, the order is
not right.
Dave
