How to display bank info in trunking...
ronenp
Hello
When I check the menu/back button i see a line "display babk" :eek:ff
how do i turn this to on .... ?
I didnt see anything mentioned about it on the scanner .....
2) is there any quicker way to transfer a freq to memory other then turning the knob so much (say i want to enter it to mem 500) .... ???
Thanks forward
Ronen
http://www.ronen.org
scanfan03
Houston, Texas
I think you may need to give us a little more info, like what scanner model you have, and what program are you using?
ronenp
more info
Sorry I forgot , The scanner is BC259D
and no external program it is what happened when i press the following button i described .... and i do it while listening to Trunked system ...
if i press it in regular conventional channel i get a difrent info ...and the Bank line dont apear there ...
Thanks Forward
Ronen
ronenp
Thank
Yes I ment the 296D
Ill try it ...
Where is it documented ??
i also discovered that pressing the Freq Button for two seconds toggle between banks / dial ..... selection
Ronen 4Z4ZQ
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Re: Thank
ronenp said:
Yes I ment the 296D
Ill try it ...
Ronen 4Z4ZQ
You can also press SRCH to scan ID SEARCH, this scans banks, not bank list. Pressing SCAN returns to ID SCAN, this scans bank list, not banks.
The exception to both is when you are also scanning conventional frequencies in the trunked bank. This will alternate between ID list for trunked and banks for conventional during ID SCAN Mode. In ID SEARCH, the scanner stays in banks but alternates between ID SEARCH and conventional SCAN.
