How to get US frequencies into freescan
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I don't know if the web service has been updated to address this yet - assuming it hasn't, what scanner are you trying to program? There may be a work-around
best regards..Mike
w2xq
Mentor
Burlington County, NJ
Yes, I would also like to know how to do so using the Win500 software. I thought I was the only one with this question (grin).
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Well if you use FreeScan (again assuming you can't do it with the web service), you can do it with the EZ Grab function - it's fully defined in the user guide; here's the reference...
Freescan EZGrab - The RadioReference Wiki
This is freeware, so don't be concerned about paying for another utility...
I don't know about Win500, Tom, sorry old friend...best regards..Mike
cpuerror
Ontario, Canada
You just need to click on the American flag in the import screen. You can also turn off Canadian mode and it will select USA frequencies by default.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yeah, I forgot about that, having set that up as my default long ago...thanks Assaf for the reminder
Mike
DonS
Franktown, CO
If you're using the current version (2.04) of Win500, the "nationwide" frequencies supplied by the latest version (9) of the RR interface appear under a new "Nationwide" item in the list of states.
If I wanted to import the nationwide USA frequencies, I'd do this:
* File -> Web Import -> RadioReference.com -> Conventional frequencies
* Select "United States"
* In the list of states, select "Nationwide"
* Select the agency, then category/subcategory/frequency
c5corvette
*REBANDED*
I just did this with ProScan 4.7 and was able to import all of the NIFOG channels by selecting Nationwide > Interop.
Very cool. (I can't wait until Uniden figures out how to incorporate this into the Home Patrol scan rotation.)
The only complaint would be that the GPS data that it downloaded didn't appear useful. It downloaded 37.16000, -98.080000, 125 range. (That range is only really good if I live in Kansas.)
There must be some bugs in the Web Service or with ProScan, because if you look at the database...
http://www.radioreference.com/apps/db/?action=locPop&scid=64500
... the range is actually 1800 miles.
c5corvette
*REBANDED*
I must be missing something, I've looked everywhere through the program (or at least I think its everywhere) to find out where/how to import "USA" frequencies.
RadioReference.com - Scanner Frequencies and Radio Frequency Reference Database
Could someone kindly offer any assistance on how to import these nation-wide frequencies?
Alex, IIRC, Freescan doesnt support the nationwide functionality yet.
best regards..Mike
Mike, version 9 of the RR Web Service does support this 'Nationwide' Functionality.
Assaf, when I click on the American flag, nothing happens. Can you confirm your software is using the latest version of the web service or at least tell us what version it is using?
ProScan
Software Provider
Ontario, Calif.
There must be some bugs in the Web Service or with ProScan, because if you look at the database, the range is actually 1800 miles.
The max range that can be set on the XT type of scanners is 125 miles so anything over that in the RR database will show in ProScan as 125 miles.
BCD996T and BCD396T max range is 50 miles.
EDIT - Correction. I meant the BCT15. The BCD396T doesn't use location data.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As I mentioned before, you can use EZ Grab in FreeScan to copy the nationwide frequencies. That's a useful work-around until Assaf (presumably) updates the version of the web service so it can access them...best regards..Mike
c5corvette
*REBANDED*
Holy Crap. Thats a big piece of the puzzle I wasnt aware of !!!
So the workaround for Nationwide stuff is to not check the box to use GPS scanning.
However, for statewide stuff with larger states such as California, Texas or Virginia, there is no simple solution.
cpuerror
Ontario, Canada
Yes, the next version will include this update.
