How to get VX-800 to signal (tones/beebs) after ptt release???
Jetprofet
Hey everyone. I'm having a hard time programming my vx-800 to signal after transmitting. I thought I'd be able to get it programmed through the ANI/DTMF options but no luck so far. I'm thinking that I'm doing something wrong. Anybody have some advice?
robertmac
No roger beep
I wasn't aware that the VX-800 had this capability. A lot of professional radios do not require this annoying [to some] feature. When in doubt CTFM aka manual.
4-crime
NY, NY
Are you referring to MDC-1200 signaling? If so you will need the VMDE-200 chip from cimerron technologies in order to get signaling to work in your VX800. Also when programming the chip in the radio you have to make sure the firmware in the radio is at least version1.54. If it is not than you will not be able to program it. You would have to get a firmware upgrade.
