How to go to Field programming mode on a VX-P929 & 829
SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
I figured out the Sequence to go into field programming mode.
I searched high and low for these settings and no one has posted it on any of the normal radio forums.
Turn radio off, Press and hold both bottom Side buttons down Lamp and Mon while turning radio on. Simple.
madox01
how do you go though all the options just picked up a vhf one on ebay
LZJSR
California
Can you clarify? The key functions are user programmable, so you push the two round buttons below the PTT button, and then also the LAMP and MON buttons that you have set up in the Key Assignments part of the programming, or two specific buttons (like the round button above the PTT and the orange button, for example), then turn on....
gdsteele
I have to use the FPP dongle with the switch that attaches to the mic port. I can't get the "button trick" to work on mine.
