I am scanning using favorite lists. I think it was ft dodge police. they were testing equipment driving around city checking reception. Webster County is supposed to switch over to ISICS by the end of the end of the month, I believe. I will submit the info when I find out what they are. You will have to point in the direction on how I go about doing that.
If this is the system you're referring to:
Iowa Statewide Interoperable Communications System (ISICS) Trunking System Profile
www.radioreference.com
Look toward the top of the page:
The submit button, for any trunked system, will be in the same area. Press Submit, and that takes you to a screen where you can enter the information to be submitted. Be sure & note what agency the TGID is used for, what is the actual use (PD Dispatch for ??? city, a different function?), and if you hear it referenced by a specific name ("Fort Dodge Ch 2" for example) include that as well.
For your county, the Submit button is also at the top of the page, but over towards the right side of the page.
Note either in your trunked system submission that the TGID is for Fort Dodge PD (or whatever agency uses it), in Webster County, or also submit a note through the county's page that Ft. Dodge xxx has moved to ISICS, or that their dispatch is patched to the talkgroup on the trunked system (a patch would be the case if you were hearing the same thing on both the conventional dispatch (or other conventional channel) as well on the talkgroup you submitted.
