DaveDesjardins
Hi, i would like to know how to alpha tag the unit id?
I didn't find this in the manual.if you look in the manual you will find the answers you are looking for
To enter a Unit ID (Radio ID), press (.)no once then enter the ID and press E/yes. |
Notes: To view unit IDs you have to turn the option on in the 'Settings' menu. Other channel attributes (alerts, etc.) will not be applied to Unit ID channels. |
Page 61 Edit NameI didn't find this in the manual.
What page is it on? Or are you just wasting our time with a non-response?
Let me know if it actually works.I didn't even know you could edit the unit ID and put a name to it.
In previous scanner versions, you have to put an i (small eye) in front of the unit ID to name it. (Ex: i12345-Eng. 1) x36hp/SDS series scanners, you just have to put in the actual unit ID and name it.Let me know if it actually works.
It didn't work for me.
I have all of the UID's in a text file.it does work but you have to remember the uid number to punch it in then you can rename it
Have a note pad ready to write down those you would like to save, then open up the program and add them in.Doc, it does work but you have to remember the uid number to punch it in then you can rename it .the only ones that I renamed are the three digit dispatcher uids. I cant figure out how to save the uids without remembering them off the top of my head to put the numbers in. Theres got to be a better way! I wonder if you can do it in Freescan?
Try it in the menu - Program System ... Edit Channel. Pressing ".no" will show an "i" then enter in the UID.I have all of the UID's in a text file.
On the 325P2, nothing happens when I press the NO key. Whether it is stopped OR Scanning
That names the talk groups - not the individual radios.Try it in the menu - Program System ... Edit Channel. Pressing ".no" will show an "i" then enter in the UID.
I don't think so because the TGID starts with an "i". Just like I-CallsThat names the talk groups - not the individual radios.
It's not a NEW channel. All of the channels are programmed.On a new channel,
