BCD325P2: How to name unit id?
ProScan
Software Provider
Ontario, Calif.
It's not a NEW channel. All of the channels are programmed.
It's on an individual radio's UID.
Perhaps you could create a new group called UIDs. Then add new channels just like TGID channels except prepend an "i to the TGID by hitting the .No button
jonwienke
More Info Coming Soon!
VA
Then you'd be better off editing the UID name list for the system instead of going in to the channel settings.
YoShep69
Central Illinois
Menu
Program system
Select system
Edit group
Select group
Edit channel
New channel
Enter ".no" followed by radio id. The display will say Input TGID, ignore that.
The scanner will treat it as another channel. Navigate to that channel, and edit the alpha tag.
This works on my XT and P2 radios.
Greg
ProScan
Software Provider
Ontario, Calif.
Thanks.
For over 1000 uid's this ought to take about a year. :ROFLMAO:
Or a few minutes with ProScan using the Find & Replace utility.
Basic steps are:
1. Download from scanner to ProScan
2. Create a new group called UIDs or whatever you want it named (optional)
3. Copy & Paste the TGIDS from an existing group to the new group (optional)
4. Use the Find & Replace utility with the settings in the image below
5. Upload to the scanner
phask
KZZV - SE Ohio
Basic steps are:
Very similar to what I do to keep data the same between X and SDS series and 996 series.
