ErikVanR
A friend has purchased a 436HP to replace his Radio Shack PRO-96. I am assisting him in setting it up and using it, but I am stumped on how to operate this thing like a typical modern scanner, where you use software and a PC to write a program spreadsheet for everything the way you want it (and nothing you don't want) and then load it to the radio. Or hand program in a few frequencies if you want. I'm not a novice with radios; I've used Win96 software for years with my PRO-96/2096 units, and FreeScan for my BCD325/996P2 units. I also use and program Yaesu/Kenwood amateur transceivers and write/edit codeplugs and program the Kenwood and BK (Bendix-King) VHF/UHF mobiles and portables at work. Some of the HomePatrol terminology is also unconventional: Avoid? Department? I used Sentinel to "load it up" just to get it going, but now I want to "drill-down" and only enable the few systems and channels he wants to monitor, but still be able to easily lockout a few of those and then enable other nearby systems/channels if needed.
