How To Program P25 for Ham on APX 8000?
MFG_rrt
CPS R18.00.05.
How do I properly program a P25 amateur radio repeater into my radio? Do I need to create a separate Conventional System, and then link a Conventional Personality to it? The only info on RepeaterBook for the repeater is:
Downlink:443.77500
Uplink:448.77500a
Offset:+5.0 MHzb
P-25 Digital Enabled
NAC:002
Default Reflector:
County: Harris
K2NEC
Yes you need to have a conventional system set to P25 and you need to assign that system into the conventional personality.
MFG_rrt
The correct conventional system type is ASTRO, not "P25".
Thanks, I assumed that since that's what shows in CPS. Now I just need to get close enough to the repeater to test my settings.
Thanks.
