How to Program Whistler WS1040 and WS1065
tvengr
Well Known Member
Baltimore County, MD
I am working on the ARC500 file. Which programming cable do you have for the scanner? Did you install the driver? If you have the Whistler cable, save the attached driver installer file to your computer and extract. Run the extracted Setup.exe file to install the driver.
  • CDM20830_Setup.zip
tvengr
Well Known Member
Please see my previous post about installing the cable driver. Here is your ARC500 file. It is set up to select sites by scan list. Your local site is ICAWIN Blackfoot in scan list 1. You are able to toggle sites on and off by pressing their scan list numbers (1 thru 4) on the scanner keypad. Turning off all 4 sites will turn off the ICAWIN trunked system. A trunked system must have at least one site enabled to function. Conventional frequencies are in scan list 5. All 5 scan lists will be enabled when you first upload the file to the scanner. You will want to adjust the squelch using scan list 5 with the conventional frequencies. While scanning the frequencies, turn the squelch knob counterclockwise until you hear noise. Slowly turn the knob clockwise until the noise just disappears. That will be your optimal setting. I added the Pocatello site in Bannock county to give you good coverage of the Fort Hall tribal police. You also have all of the Bannock County talkgroups. Some abbreviations: BC & Bing=Bingham County. Ban=Bannock County. Chub=Chubbuck. Poc=Pocatello. Ink/McC/Arim=Inkom/McCammon/Arimo. SO=Sheriff's Office. ISP=Idaho State Police. I also included all of the statewide interop talkgroups for any major events in your area. Save the attached zipped file to your computer and extract. Open the extracted file with ARC500. If your programming cable has a mono adapter on the end, remove it. The scanner requires a stereo plug. Connect the programming cable between your computer and the PC/IF jack of your scanner and turn the scanner on. Go to the Scanner tab in ARC500 and click on Upload to Scanner. Please let me know if you have any questions. Scan lists as follows:
SCAN LISTS:
1. ICAWIN Blackfoot
2. ICAWIN ShelleyBt
3. ICAWIN EastButte
4. ICAWIN Pocatello
5. Bingham Co Conv
  • Bingham Co ID GR5.zip
gjackman96
I believe I have one downloaded now I will have to install the other and see if things work. Thank you.
gjackman96
Was able to get everything downloaded and the scanner working I have heard fire and Pocatello some are broken up and can't understand very well do you suggest an antenna for them? Thank you so much for your help! I was about to give up.
tvengr
Well Known Member
I'm not sure how to turn scan list 5 off?
Press 5 on the scanner keypad while scanning. Pressing the scan list number on the keypad will toggle the scan list on and off. For scan lists 11 thru 20, press FUNC and then the scan list number (Single digit 1 thru 0). Example: Scan list 11 = FUNC and then 1. 0 = scan list 10. FUNC and then 0 = scan list 20.
tvengr
Well Known Member
Whistler 1040 model.... do these require updated downloads on occasion?
Yes, as there are changes in conventional frequencies and trunked systems in your area. You can use ARC500 or PSREdit500 software to program it. I use Butel ARC500 Basic to program my Radio Shack PRO-106, the older brother of your scanner. Both use the same software. You can program the scanner manually, but it takes a lot of time. Looking at the database, the Clay County Sheriff and West Point PD are DMR. The MSWIN statewide trunked system, which is used by Clay County, is P25 Phase 2. The WS1040 cannot receive DMR and is capable of P25 Phase 1 only. It is the wrong scanner for your location.
PeabodyMac
West Point, MS
Thank you!! It worked for about a year, went spotty, and then went silent. I’ll have to start looking for a new scanner.
bowserbob
billings mt
ahhh several nasty words i cant type here come to mind im trying to upload all my trunking channels on my ws 1065 using the win 500 software the software was the easy part then the scanner is asking so many questions i dont have a clue im an old tube and teransistor tech this digital world shorts my circuits
fxdscon
¯\_(ツ)_/¯
Perhaps you could tell us what questions you are being asked..... we can't see what you're looking at.
bowserbob
billings mt
the win 500 software loaded into my ws 1065 fine rebooted now its asking me to press new to create objects
fxdscon
¯\_(ツ)_/¯
The Win500 software does not load into your WS1065, it loads into your PC computer. Do you have the scanner connected to your computer with the proper cable?
Are you asking about what you're seeing on your scanner screen, or are you asking about what you're seeing on your computer screen?
For any kind of meaningful help, you will need to be much more accurate and detailed with your questions.
bowserbob
billings mt
greetings ok so yes the software loaded fine onto my laptop i got my key to work i found all my trunking stuff for here in yellowstone county my ws 1065 is hooked up via proper usb cable i hit the button that says upload to scanner i did that the scanner rebooted i hit the enter key it than prompted me to hit the new button f 1 now it says talkgroup on top scan list right below blinking then tsys right below that and this is where im lost
rhodester
Saratoga County, NY
well so much for finding help here
If your trying to enter the following don't bother because the T means it is P25 phase 2.The ws1065 only does P25 phase 1.The TE talk groups are fully encrypted.
Yellowstone County
DEC HEX Mode Alpha TagDescriptionTag
12315301bTYellowstone SOSheriffLaw Dispatch
123733055TBillings PWBillings Public WorksPublic Works
124013071TEBillings PD DispBillings Police Main DispatchLaw Dispatch
124033073TEBillings PD EncBillings Police EncryptedLaw Talk
124053075TEBillings PD EncBillings Police EncryptedLaw Talk
124083078TBillings A/CBillings Animal ControlLaw Talk
124173081TBillings FD MainBillings Fire MainFire Dispatch
124193083TBillings FD OpsBillings Fire Ops 15Fire-Talk
124243088TBillings FD Tac1Billings Fire Tac 1Fire-Tac
124253089TBillings FD Tac2Billings Fire Tac 2Fire-Tac
12426308aTBillings FD Tac3Billings Fire Tac 3Fire-Tac
12427308bTBillings FD Tac4Billings Fire Tac 4Fire-Tac
12428308cTBillings FD Tac5Billings Fire Tac 5Fire-Tac
12429308dTBillings FD Tac6Billings Fire Tac 6Fire-Tac
12430308eTBillings FD Tac7Billings Fire Tac 7Fire-Tac
12431308fTBillings FD Tac8Billings Fire Tac 8Fire-Tac
124323090TBillings FD Tac9Billings Fire Tac 9Fire-Tac
124333091TBillings FD Tc10Billings Fire Tac 10Fire-Tac
124343092TBillings FD Tc11Billings Fire Tac 11Fire-Tac
124353093TBillings FD Tc12Billings Fire Tac 12Fire-Tac
124363094TBillings FD DispBillings Fire DispatchFire Dispatch
1245030a2TBillings Air PDBillings Airport PoliceLaw Talk
1245230a4TBillings Air FDBillings Airport FireFire-Talk
1246030acTBillings Bus 1Billings Met Bus Ch1Transportation
1246130adTBillings Bus 2Billings Met Bus Ch2Transportation
1246230aeTBillings Bus 3Billings Met Bus Ch3Transportation
1249030caTBillings Air OpsBillings Clinic Air OperationsEMS-Talk
