How to put a xts2500 in program mode
GTR8000
NY/NJ Database Guy
BEE00
You read and/or write using CPS...the radio will go into "program mode" on its own once a connection is established.
prcguy
If it has an FPP feature you just press the FPP button, enter a password if needed and follow the prompts to change freq, tone, etc. If the radio is not equipped for FPP then CPS with programming cable is the only way to program it.
sniper19
Ok. I have the software on the way. Just making sure I didnt need to put in any programming mode before I tried it.
GTR8000
NY/NJ Database Guy
BEE00
Nope, the process is automatic when you read or write to the radio.
com501
You DO realize that the XTS2500 and the XTS3000 use two different software apps and also require different programming cables, right?
cmdrwill
So Cali
AND remember the FIRST RULE of Programming:
Read the radio and save that 'codeplug' to a safe archive, before doing any changes.
Then you have that saved information in case something goes wrong.
And I always read the radio first and save that cp, and then make changes.
