How to put on a connector onto Lmr-400
Bonkk083
Union, SC
I have a N male right angle never have put one before and prepping coax how should I cut off each part of coax I usually cut off 1 inch of the outer jacket
Bonkk083
Union, SC
Is the connector made by Times and an EZ version? If so that really needs the Times cable prep tool to install as the dimensions are critical and you have to deburr the center conductor.
It's Konnectrf connecter
G7RUX
If you have no instructions for it then i would suggest carefully cutting back the outer and screen about 2” back from the end, pop the backnut, washer and compression seal onto the cable back from the trimmed end and push the “top hat” into the screen/sheath. Then offer up the assembly beside the connector and see how long the core needs to be to reach the solder fork on the pin. Then strip back the insulator a couple of millimetres so you have some exposed centre conductor. If you're happy with how it looks, assemble the connector and check that the centre conductor is the correct length and sits nicely in the solder fork; solder it in place and pop the cap on.
Done.
Bonkk083
Union, SC
Can this be used for connecters and should I use flux
