Well if all you heard was static then either
A. there was nothing on
B. you didnt heard anything due to your RX, or antenna
C. you werent in the right mode
the mode need to be either USB, or if you RX has the ability CW REVERSE which I find to be the most acturate
If you did heard the broadcast sounds like high pitch whines and notches and nicks kind of like a loud annoying printer
Also make sure Multipsk is set in the right mode for your sound card, in the start up screen click on Mixer Control and make sure your input or microphone is checked, what ever input it is that you are using
In multipsk theres not any "real" settings you need to be in except fo HF FAX, its all "preferences from there" what you like.
Although its nice to have LPM(lines per minitue) at 120
and IOC(index of cooperation) "size" at 576
hope I helped???
