lucky43113
i was wonder if it was possible for my bcd996p2 to record audio only when a certain group keys up for example local fire dept .. i have everything added and all quick keys are set up
The 996P2 does not have any native recording capability. You could, though, connect a voice activated recorder via the external speaker jack. With this, however, you would be recording all the audio your scanner receives.
I'm not sure if/how scanner control software handles recording, as I only use the software to program
As long as DMR systems are not in use, FreeSCAN would also work.
Just remember that in using the pc and software to record, audio is not recorded via the USB cable. Instead, use an audio patch cable to feed transmissions from the scanner to the mic, or line, input of your pc's sound card.
according to their user guide it does and i saw the option in the software just not sure how to set it up
The exact setting, and it's location, will depend on your systems sound card and it's options.i got it working thanks guys the only thing is while recording I can not hear it but thats not a big deal i can just use an external speaker to fix that. Im a ufo investigator and when im out on an investigation i like the option of having this scanner record while im gone to see if i pick up any air traffic that could be related like military etc..
You might want to look into PROSCAN also to make your 996p2 log record and be remote controllable
I just like my PROSCAN better than FREESCAN plus I am using DMR P25 Phase 1 and 2.
I was just making you aware of something else and I am also running it 8 times on 8 different scanners on the same PC at the same time. I can sit at my Fire Station and do anything to my scanners that I can do at my scanner desk.
