How to remove?
K9GTJ
Kokomo, IN
Anyone know how to remove the little tray from my Ford Ranger? I have not been all the way under the dash but I don't see any screws visible.
RISC777
Check out a local auto parts store. Look for the the $17 to $20 Chiltons or Haynes manuals for your year, make, and model. Usually they'll let you look through one without having to buy it. Or you can buy it and have it for other "do-it-yourself and don't pay someone labor charges" projects/jobs.
FPO703
Planet Earth
You might even do a google search. There are quite a few sites out there for the armchair mechanics to hang out at.
fireside
Tama IA.
I also have a Ranger. The cup holders have an insert, pull them out and you should see the screws if i remember right. Its been a while since i took mine out. With the cup holder removed, their is a plastic part that is screwed down as well. Took that and drilled a couple holes to line up with the 2096 mounting bracket. When i get the time i'am going to make something to get it up higher. Hope this helps.
kc8qch
Cincinnati, Ohio
RE: How to Remove
I had a 1998 Ford Ranger. If you pull the cup holder inserts all the way up, they pop out. Then take a screwdriover and lift the rubber bottom covers off the bottom of the cup holders. Under there is a locking knob. Take a screw driver and turn it till it unlocks (under both cupholders) and the whole tray will come out. It mounts on a flat plastic piece that you can then use for a mounting plate. I did the same thing and had a "stack" there when I had my Ranger. Took me years to figure the darn thing out.
