CycleSycho
uP Appl Ver: U4.5
DSP Voc Ver1.6, App Ver: 3.0
DSP build#: 101
So, how easy will it be to 'revert' to the original RS668 mode? Thanks in advance, for helping me get this radio 'Whistler' ready!
Hello,Am wanting to roll back the Eric mod to be able to send my converted WS1080 to Whistler as an original RS668 so I can get it officially updated. Is there some kind of magic steps that I need to do with the Eric tool? I HAVE NOT updated the radio since first converting it, it has;
uP Appl Ver: U4.5
DSP build#: 101
So, how easy will it be to 'revert' to the original RS668 mode? Thanks in advance, for helping me get this radio 'Whistler' ready!![]()
Hello,
Whistler only has problems with "locked" scanners. I and others had no problems with modified scanners as long as Whistler's code to disable firmware updates on the scanner was not triggered. If you can still receive DMR, then it is not "locked".
Personally I prefer people not to convert back, as it shows Whistler that we are not all thieves that want DMR for free. They may be using the "hacked" notation on the repair slip to keep track.
If you do want to revert back, just change the firmware type from WS-1080 to Pro-668 in the settings. You can then download the Pro-668 firmware file and then do a firmware update with the file you downloaded.
73 Eric
Hello,OK, tried to 'revert', the CPU update fails every time. It seems like I need the PRO668 .bin file to load up into the radio but I do not have that file. I was originally led to believe that bin file was in the tool but it isn't anywhere I can find it. Anyone have that file so I can restore my PRO668 to OEM?
Hello,
The bin file is not in the tool, you need to download it by first changing the firmware type to Pro-668 and using the download function. Then you select the file you downloaded, which should have Pro668 in the filename, and do the firmware update.
73 Eric
Hello,
73 Eric
uP appl ver: 4.6
dsp voc ver: 1.6, app ver :3.0
dsp build #: 101
Is this safe to send in to Whistler for upgrade?
Not a peep out of Whistler Wendy today on fixing radios that were locked due to WHISTLER DSP 3.1 zero day code. NOT Eric's code.
There are two versions of DSP 3.1 I have an earlier version and it was still receiving DMR and when I sent it in. So it'll be interesting to see the ones that are locked are replaced with TRX 1 radios. One thing for certain there is going to be a backlash. It has started already.
I'd be really surprised if they were to decide to replace the locked scanners for new ones, but even if they did, I'm sure it would be more likely to be a WS1088, instead of a TRX 1.
Chibipaw just posted the Whistler options if they have problems with your scanner
