How to set ini file in Tronquito
Saint
Fort Erie Ontario Canada
I have a mpt 1327 system I'm trying to listen to in the 400.00 mhz band, the control channel I am listening to is 420.175 how do I set up the .ini file to listen to it.
This is what I have started to receive
New network...
SYS 0x50a1 Unknown network - C.C. 460.0000 MHz
SYS 0x50a1 ACKK General Prefix: 0x0 Ident1: 0x1ff9
SYS 0x50a1 GTC Channel 0x26 Freq: 460.4750 Mhz Prefix: 0x0 Ident1: 0x1774 Voice
SYS 0x50a1 GTC Channel 0x26 Freq: 460.4750 Mhz Prefix: 0x0 Ident1: 0x10b Voice
SYS 0x50a1 ALOHA
This is the way the file is set now
[0x4009]
Base=4600000
Offset=2
Step=125
CC=4609000
Name="(UHF) T1"
Steve
DaveH
Ottawa, Ont.
Have you been able to figure this one out Steve? From the look of it, the base would be 420.0000, step 125 (12.5kHz). The offset might need to be tweeked; for some reason I found it to be off 1 or 2 channels from expected (built-in compensation?). Watch the channel frequency it reports during a call, and adjust if necessary.
I found one system where the step is actually 6.25kHz even though the channels are on 12.5kHz grid. The S/W truncates the last digit, causing roundoff errors that increase with the channel number (I verified this). This shouldn't be a problem in your case (I hope).
Dave
Saint
Hi Dave, I really have not had any luck with the program and deleted it, I know that other people are working on new programs that will be a lot better, so I think I will just wait till these programs come out, I just wanted to play around with the program to see what it will do. To bad there is not a scanner radio that will trunked this kind of system, anyway thanks for the info Dave.
Steve
