How to set the Priority on the GRE 500/600
jimg
So. Middle TN
Would someone explain how to correctly set the Priority on the GRE 500 and 600 on conventional as well as digital systems? Thanks in advance for your help.
kikito
North Pole, Alaska
Just press FUNC + PRI on the talkgroup or frequency you want as priority. You'll see the the 'p' on the right of the screen go to a capital 'P'. After you start scanning, press FUNC + PRI again and you'll see the 'pri' turn to capital 'PRI' to let you know the Priority function is active.
