How to Set-Up T-Tables for MOSWIN system on my Radio Shack 651
17TLS02
Rocheport,MO
Hello, I do not understand what T-Tables first of do for your scanner but I would like to program it in on my MOSWIN system that I am already monitoring on my Radio Shack 651. I live around the Columbia Area and have programmed in the Columbia 700 frequencies and Ashland's frequencies and some other sites to if that will help you tell me how to program in my T-Tables for my system. If any one has any information about what I am talking about and how to do it please reply. Thanks, Tyler.
talkpair
Clinton County, MO
The trunking tables are automatically downloaded to your scanner from the control channel when you set your TSYS object up with P25:Auto.
The Branson, Arcola, and possibly Alton sites may require special handling if you have decoding issues with voice channel 161.99375 MHz.
17TLS02
Rocheport,MO
Oh okay so the T-Tables does nothing special to the scanner that is good?
talkpair
Clinton County, MO
The values in the table are inserted into a mathematical formula which is used to translate a channel number to a frequency.
Other than the sites I mentioned above, there is nothing to be gained by tweaking the table.
