ProScan: How to setup up Proscan on a laptop to hear audio
Bonkk083
Union, SC
How do I setup Proscan to hear audio on a laptop I did it one time but can't remember how I did it
ProScan
Software Provider
Ontario, Calif.
Go to the Audio Control - Monitor & Test tab then select an audio service using then click the Loopback box.
If not using an audio service then pick any such as Recorder. The audio for the recorder would have to be setup in the Audio Control - Recorder tab.
Bonkk083
Union, SC
When setting up port forwarding on my Netgear router do I need to use the ip address that my pc uses or the scanner uses, trying to setup web server
ProScan
Software Provider
Ontario, Calif.
Use the computer IP address.
{edit} Both of your questions are answered in the manual. To access the manual, click Support in the menu then Manual.
ProScan
Software Provider
Ontario, Calif.
I forgot my registration name and key how can i get it
Keys are handled via email only. Keys are usually handled within a day when the request is initially sent via email and I can lookup your email address or other identifiable info
If you don't mind, can you post your ProScan related questions here.
{edit}
Per the manual
Lost keys are sent at no charge. Key Request must be done via email.
This is the 3rd question you asked that is answered in the manual.
See post #4 on how to access the manual.
