Pro-651: How to switch bands in SRCH mode
Johnson1522
Oxford, NC
While using the search feature to scan Ham frequencies, the scanner will cycle through 6 different ranges. Is there a way to cycle through them? For example, if the scanner is currently cycling through item 4 (70cm) and I want to jump to item 2 (2 meter band), is there a key combination I can press to jump directly to item 2?
The manuals show that I can change the direction of the scan up or down. They also show how to add/remove items from the scan list. I can't seem to find how to navigate them, though.
sprite1741
Keypad numbers turn bands off or on , 1 is 28Mhz , 2 is 50, 3 222, 4 is440, 5 is 900, 6 is 1200 Mhz. You can turn them off and on depending on which band you want. Aircraft is the same way for civilian or military air and public safety as well for low, high, uhf, 700, and 800. Great feature on these.
Johnson1522
Oxford, NC
Thanks for the reply, Sprite. I'm actually trying to navigate between them without turning them on or off. Is there a way to do that?
