how to tell direction of plane
gabyjan2291
tifton,ga
is there anyway to tell the direction a plane is going by his id number (as with rr). i live about half way between atl and jax and listen to their weather related course changes. they have good weather radar and i would really like to know if the "cell" is heading my way.
AndrewC75
Kennesaw, GA
They are also given heading instructions from ATC from time to time.
"Delta 794, turn right to 090" means turn due east.
If they're already flying a heading of 090, they might request a deviation of 20 degrees right for weather, which would put them at 110, or east south east:
Aircracft: "Delta 794, reqest deviation 20 degrees right for weather"
ATC: "Delta 794, deviation approved, 20 degrees right turn to 110".
Or, you could just use a ground-based weather radar from any of a number of sources. My favorite is http://www.wunderground.com
rdale
Lansing, MI
Weather radar images don't show planes or their direction of travel...
DPD1
Once you learn the sectors and associated freqs, you can start to understand what way they are going (or route they are taking) by listening to which freqs they switch to next. It's pretty predictable after a while, since they obviously try to stick to a set method of controlling as much as possible.
Dave
http://www.DPDProductions.com
- Custom Scanner, MURS, GMRS, & Ham Antennas -
AndrewC75
Kennesaw, GA
n6766j
Walland, TN
Altitudes
Certain cruising altitude are assigned for aircraft flying in a particular direction. For aircraft under Visual Flight Rules (VFR) and heading North through East to South that altitude is Odd thousands plus 500 feet (e.g. 5500 or 7500). For aircraft flying South through West to North the altitudes are Even Thousands plus 500 feet (e.g. 8500 or 10500)
For Instrument Flight Rules cruising altitudes, the same rule applies without the 500 foot addition. You can see that aircraft flying in opposite directions will (ideally) always be separated by 1000 feet vertically when on the same type of flight plan. Until recently there was a 2000 foot vertical separation criteria for aircraft flying above 29000 feet. That restriction is now only 1000 feet for aircraft properly equipped.
gabyjan2291
tifton,ga
n6766j,thanks so much, your info helps a lot in trying figure out which the planes and their are going,wish i had have looked yesterday. we were under tornado watch and listening to when report of a tornado touching down in omega.
found out today where omega is (10.miles to southwest ) no we werent hit,but it made me really nervous.
a/c were hunting better rides, going around, and i think circling ? bad day yesterday was
bluesman905
Durham Region, Ontario Canada
Great site.....thanks for the link.
MacombMonitor
It's been my observation, planes always fly in a forward direction!
blinddog50
Undisclosed urban location.
Try going to www.ATCmonitor.com
In the area you live in it might be especially helpful.
gabyjan2291
tifton,ga
malombmonitor i almost fell out of my chair when i read your reply. now ive got this picture of these big jets flying backwards.
blinddog50 oh thank you for the link its great!
