How to write the radio without reading? Motorola HT 1250
Firedep701
Mount Dora, FL
so me, being not very smart, decided to try programming my radio without first Backing up the Original Codeplug. I now have the codeplug but i cannot Write it to the radio because he program gives me an Error 4 and says the radio cannot be read. Can anybody help me and tell me how to program the radio without reading it. It is a Motorola HT 1250 and i have a ribless cable. I am using Professional Radio CPS version R06.09.06. PLEASE HELP!!! all help is very much appreciated!
Thank you,
Brian Clough
Edit/Delete Message
btritch
Paragould/Greene County AR
So I see you DID place it in another location, Though not in the general, In the motorola, Uh oh, A mod would call this a "Cross Post"
Just out of curiosity, Is there a "reset" button on there anywhere, Try that perhaps?
Astro25
Chicagoland
The Waris series radios do not have a reset button.
Current CPS is R06.10.02 per my MOL and what I'm using here. Try a newer version and see if this helps.
Astro25
bravo14
Polk County FL
Astro25
is there any new features to the radio? or just software update?
btritch
Ok..
Ok, Well I admit right now that I do not have one of these radio's, I'm not even sure of the type it is, I just know that some have resets and some don't.. It was just a suggestion, I wasn't saying I knew a lot about them because I don't. Just trying suggestions to help out former RR Members.. A little info to go on is better than none...Hmmmm......Is there a program that will work with this radio like we have for the scanners such as win500 etc. but for those radio's?
Just tossing around suggestions here...
bravo14
Polk County FL
The software will work only with ht750 and ht1250. Not sure about the other moto radios. The software for these 2 are Professional radio CPS.
Firedep701
Mount Dora, FL
All the help i can get is much appreciated thank you. yeah i have the program but everytime it goes to write to the radio it has to read it to make sure it can accept the new code but it can't read the current code because it's corrupted
Firedep701
Mount Dora, FL
I do have that software but i didn't know if that software had something where you can write the codes to the radio without having to read it
bravo14
Polk County FL
If I do send a coldplug to you. If you want to try to do what ever you need to in the software than write it to the radio.
