K2RNI
I just bought a Pro-91 and am interested in scanning the 902-928 band, would the RS 800 MHz handheld scanner antenna still yield decent performance here or should I just stick to the all-purpose duck included on the scanner?
They work good on 900 MHz.
I have two of them. I checked them on an antenna analyzer and both were resonant around 870 MHz.
For an experiment I cut one to 935 MHz and the other I lenghtened to 856 MHz.
On a scanner you can't tell the difference on either band even after I modified them.
. Experimental stuff, a few ham repeaters/Simplex depending where you listen. :wink: 73, n9zasWhat is on the 900 mhz band ? Surely not public safety?
There are a lot of commercial trunked systems on 935-940 MHz. Also some conventional systems.What is on the 900 mhz band ? Surely not public safety?
FYI the Radio Shack 800MHz scanner antenna catalog #2000283 (https://www.radioshack.com/products/radioshack-800mhz-scanner-antenna?variant=5717063941) is $24.99 but it is currently out-of-stock online. You can get the same exact antenna under the Remtronix brand for $21.95 from Universal Radio (Remtronix REM-800B, Diamond REM-800S Scanner Antenna). Also the Remtronix 800 MHz antenna is available in either BNC or SMA whereas the Radio Shack is BNC only.
From the product descriptions at Universal Radio: "The Remtronix REM-800B is a very compact flexible antenna providing extremely good reception in the range of 700 to 960 MHz.
It has +6dB minimum gain over a standard antenna.
This 7 inch tall antenna terminates to a male BNC connector.
The new Remtronix REM-800S is the same, but terminates to a male SMA connector.
These high quality antennas are made in Japan."
Thanks friend. People were wanting 35 to 40 on ebay for the Radio Shack.
I pulled the cap off and cut the whip shorter, replacing the cap and measuring it on the antenna analyzer until I got it resonant where I wanted it.so if ya don't mind me asking, when you did the mods did you just pop the tops and cut down one, and add to the other in the convention manner? or perhaps did you more extensively remove the opaque outer sheathing in the process?
i ask because i have always wondered about the internal-construction-magic contained within those puppies.
